SelectionColor |
Returns or selects the background color of the PowerExplorer object's cell, when it is selected. If no color is selected, or if this property is configured with the value -1 (minus one), it uses Windows default color. Usage example, including the SelectionColorInactive property:
Set PE = Application.GetPowerExplorer("SE1.SYSTEM.[5201]")
PE.SelectionColor = RGB(255, 0, 0)
PE.SelectionColorInactive = RGB(0, 0, 255)
PE.Show
