ProtectionTypes
ProtectionTypes
Link This property returns an object that allows configuring Protection Types by script. Protection Types are available on the Protections tab of the Power Configuration object. To use the object returned by this property at run time, users must deactivate the Power Configuration object before changing its properties, according to the next example.
Set pc = Application.GetObject("PowerConfiguration")
pc.Deactivate
Set p = pc.ProtectionTypes
MsgBox Typename(p) & " " & p.Count
p.AddProtection "New"
p.AddProtection "New", "NE", , 12
Set pt = p.AddProtection("New3", "NE3", "Super New 3", 123)
p.DeleteProtection "New2"
p.DeleteProtection "New3"
Dim s
s = ""
i = 1
For Each pt In p
  If s <> "" Then s = s & Chr(13)
  s = s & pt.Name & " (" & Typename(pt) & ") "
  s = s & pt.Acronym & " "
  s = s & pt.Caption & " "
  s = s & pt.Order
  If i > 23 Then pt.Name = "Name"
  pt.Acronym = i & "A"
  pt.Caption = "Description " & i
  pt.Order = i
  i = i + 1
Next
MsgBox s
pc.Activate
NOTE
Please check topic Protection Types for more information about the properties of the object returned by this property.
