ModelDriver
ModelDriver
Text Configures the file path of a library (DLL) for importing or syncing an electrical model from an external database. Default value of this property is an empty String. For more information about this DLL, please contact Elipse Software.
NOTES
This property is available for Elipse Power in its 32-bit version. For its 64-bit version, please check the ModelDriver64 property.
The library file pointed by this property must be a 32-bit version, which differentiates from its 64-bit version by not having a "64" suffix in its name.
