CommandTypes
CommandTypes
Collection This property returns an object that allows configuring Command Types by script. Command Types are available on the Commands tab of the Power Configuration object. To use the object returned by this property at run time, users must deactivate the Power Configuration object before changing its properties.
NOTE
Please check topic Command Types for more information about the properties of the object returned by this property.
