AnalogTypes
AnalogTypes
Link This property returns an object that allows configuring Analog Measurement Types by script. Analog Measurement Types are available on the Analog tab of the Power Configuration object. To use the object returned by this property at run time, users must deactivate the Power Configuration object before changing its properties.
NOTE
Please check topic Analog Measurement Types for more information about the properties of the object returned by this property.
