CurrentRetry
CurrentRetry
Number Indicates in which retry the current action is executing. This is a read-only property. If a Command is disabled (by setting its Enabled property to False) with one of its Units executing retries, this action ends in the next retry, indicating this failure through the Failed parameter of the OnCancelFinished, OnOperateFinished, and OnSelectFinished events set to True.
