DeleteType
DeleteType
DeleteType(Index)
Removes the Command Type informed in the Index parameter, which can be the position of a Command Type (starting at one) or this Command Type's Name property, if this object exists in the collection of Command Types. Otherwise, this method returns a script error.
NOTE
Default Command Types, whose name starts with the character of an asterisk (*), cannot be removed.
