RemoveFrom
RemoveFrom
RemoveFrom(idElement, idFrom)
Removes the element indicated by the idElement parameter from the Bay or Transmission Line indicated by the idFrom parameter. This method returns a Boolean indicating whether this operation is successful or not.
NOTE
For more information about the format of the idElement and idFrom parameters, please check the ID property, common to all devices.
