AddToTransLine
AddToTransLine
AddToTransLine(idElement, [idTransLine])
Adds the Transmission Line Segment indicated by the idElement parameter to the Transmission Line indicated by the idTransLine parameter. If the value of the idTransLine parameter is a null ID ("{00000000-0000-0000-0000-000000000000}"), a new Transmission Line is created. Otherwise, the indicated ID must exist previously. This method returns the Transmission Line added or created.
NOTE
For more information about the format of the idElement and idTransLine parameters, please check the ID property, common to all devices.
