AddToBay |
AddToBay(idElement, [idBay])
Adds the element indicated by the idElement parameter to the Bay indicated by the idBay parameter. If the value of the idBay parameter is a null ID ("{00000000-0000-0000-0000-000000000000}"), a new Bay is created in the element indicated by idElement. Otherwise, the indicated ID must exist previously. This method returns the Bay added or created.
NOTE |
For more information about the format of the idElement and idBay parameters, please check the ID property, common to all devices. |
