CurTargetX |
Returns the horizontal insertion position of a text on an object. This position is measured in Himetric units (a himeter corresponds to 0,0001 meters). Users can use this property and the CurX property to move a text's insertion point while moving through an object's content. When moving this insertion point to another text row, this property specifies the best position for the desired text's insertion point. The CurX property is defined with this value, if the text row is greater than the value of this property. Otherwise, the CurX property is defined as the end of the text row. This is a read-only property.
