DeleteField |
DeleteField(Index)
Removes the Storage Field informed in the Index parameter, which can be the position of that Storage Field (starting at one) or the value of that Storage Field's Name property, if that Storage Field exists in the Fields object. Otherwise, this method returns a script error.
