DeviceHigh
DeviceHigh
Number The DeviceHigh property defines the highest value achieved by this I/O Tag in a device. This property is used to perform a scale adjustment of the value received from a device before setting it to the Value property. Likewise, the inverse operation is performed before sending that value to the I/O Driver, when writing. This conversion only occurs when the EnableScaling property is set to True. Default value of this property is 1,000. Example:
Sub Tag_OnStartRunning()
  ' Adjusts the scale of temperature
  ' ranging from 0 to 255 at PLC, but it actually means
  ' 0 to 100 Celsius degrees
  EU = "Celsius degrees"
  EnableScaling = True
  DeviceHigh = 255
  DeviceLow = 0
  EUHigh = 100
  EULow = 0
NOTE
Bit values, that is, the properties from Bit00 to Bit31, are not affected by adjustments in the scale, that is, they represent the bits from the value read by a device before conversion.
