DataField
DataField
Text Configures or returns associated data to a SetPoint object. This associated data can be a field on a database table provided by a Query object, a mathematical expression with Query fields and VBScript functions (in this case, this field must be preceded by an equal symbol), or an Elipse Power Tag or property. In this case the current value of this variable is displayed when printing. Default value of this property is empty.
NOTE
The server must be executing so that the variable's value can be captured.
