Context
Context
Context(ContextName)
Returns an object implementing the context indicated by the ContextName parameter, which must be a String surrounded by quotation marks. This method fails if no object on the upper hierarchy of the object calling this method implements that context. The following contexts are available:
Container: Server and Viewer objects, that is, objects inserted in project files or on folders inside projects
Area: Alarm Areas, or any server object whose IsAlarmArea property is set to True
Device: Bay, Branch, Breaker, Busbar, Capacitor, Direct Current Branch, Distribution Load, Distribution Transformer, Feeder, Generator, Inverter, Junction Box, Line Segment, Photovoltaic Array, Photovoltaic Power Plant, Reactor, Recloser, Switch, Switch Fuse, Substation, Three-Winding Transformer, Transmission Line, Two-Winding Transformer, Voltage Regulator, Wind Power Plant, and Wind Turbine objects
Group: Group of Commands, Group of Interlocks, Group of Measurements, Group of Photovoltaic Strings, Group of Protections, and Terminal objects
SwitchGear: Breaker, Recloser, Switch, and Switch Fuse objects
Transformer: Distribution Transformer, Three-Winding Transformer, Two-Winding Transformer, and Wind Turbine Transformer objects
In addition, the following specific contexts are available:
Bay: Bay object
Blade: Wind Turbine's Blade object
Branch: Branch and Direct Current Branch object
Breaker: Breaker object
BusBar: BusBar object
Capacitor: Capacitor object
Commands: Group of Commands object
Converter: Wind Turbine's Converter object
DistributionLoad: Distribution Load object
Feeder: Feeder object
Generator: Generator object
GeneratorRotor: Wind Turbine's Generator Rotor object
GeneratorStator: Wind Turbine's Generator Stator object
GeneratorTerminal: Wind Turbine's Generator Terminal object
GridTerminal: Wind Turbine's Grid Terminal object
Hub: Wind Turbine's Hub object
Interlocks: Group of Interlocks object
Inverter: Inverter object
JunctionBox: Junction Box object
LineSegment: Transmission Line Segment object
Load: Load object
Measurements: Group of Measurements object
Meteorological: Wind Turbine's Meteorological object
Nacelle: Wind Turbine's Nacelle object
PhotovoltaicArray: Photovoltaic Array object
PhotovoltaicPowerPlant: Photovoltaic Power Plant object
Protections: Group of Protections object
Reactor: Reactor object
Recloser: Recloser object
Rotor: Wind Turbine's Rotor object
String: Photovoltaic String object
Strings: Photovoltaic String Group object
Substation: Substation object
Switch: Switch object
SwitchFuse: Switch Fuse object
Tower: Wind Turbine's Tower object
Transmission: Wind Turbine's Transmission object
TransmissionLine: Transmission Line object
VoltageReg: Voltage Regulator object
WindPowerPlant: Wind Power Plant object
WindTurbine: Wind Turbine object
Yawing: Wind Turbine's Yawing object
NOTE
Context names are case-insensitive. To check the context to which an object belongs, open its Properties Window, select the Item tab, and then check its valid contexts in the Contexts frame. In case an object defines more than one context, their names are presented in alphabetical order, separated by commas.
