Item
Item
Item(ItemId)
This method returns an Event object from the Collection of Events of any Elipse Power object. If this parameter is a text, the ItemId parameter specifies the name of an Event to access. An Event can also be accessed by a numerical index. This index must range from 1 (one) to Count. If the Event does not exist, or its index is invalid, a script error occurs.
