FlowTolerance
FlowTolerance
Number Tolerance of power flow's algorithm, in MVA (Megavolt Ampere). Corresponds to the maximum error allowed on power flow. The lower the value, the longer the time to find an answer. Default value of this property is 0.01 and its value must be between 0.001 and 100.0.
