OverrideLineColor |
When the EnableOverrideLineColor property is set to True, this property is used to define a color to use on the line color of moving objects, instead of their original color. In scripts, use VBScript's RGB method to create a color to link to this property. Default value of this property is red (RGB(255, 0, 0)).
