DigitalData |
Determines the style for digital plotting. If this property is set to True, the style for digital plotting assumes that data variation is in digital form, that is, its value relative to the last one varied instantly. Otherwise, variation is considered linear and points are connected by a line segment. Default value of this property is True. This property has no effect if the EnableAutoPlotMode property is configured in True.
