CustomConfig
CustomConfig
CustomConfig()
Allows automated configurations on ElipseX instances. A configuration option appears on a contextual menu of an ElipseX instance when there is a script linked to the CustomConfig event of the ElipseX definition. When this option is selected on that contextual menu, that event is triggered. The text that appears on this contextual menu option can be set in the CustomConfigText property of the ElipseX definition. If this property is empty, the displayed text is "Configure".
Contextual menu of an ElipseX instance
NOTE
A script linked to the CustomConfig event executes in Elipse Power Studio, where objects are not active. Therefore, its behavior is different from the usual.
