StrokeColorDeEnergizedUserDefined
Boolean Indicates whether the color of a de-energized device must be the color defined in the StrokeColorDeEnergized property (True) or else it is calculated automatically as a darker version of the color informed in the StrokeColor property (False). Default value of this property is False.
