CustomFilter
CustomFilter
Text Allows informing a customized filter for alarms, as an expression. Please check Alarm Filter's CustomFilter property for more information about the available fields for use on this filter's expression. User-defined fields can also be used on a filter expression, by using the name defined on the Alarm Server.
Altogether, messages displayed on E3Alarm list always pass through these filters:
Filter by type, defined in the FilterType property
Filter by severity, defined in the ShowCriticalPriority, ShowLowPriority, ShowMediumPriority, and ShowHighPriority properties
Filter by area, defined by the AreaFilter and SimpleAreaFilter properties
Filter by the CustomFilter property
Filter by the alarm summary, which is equivalent to the expression "Enabled AND (ConditionActive OR (AckRequired AND NOT Acked))"
Usage Examples for the CustomFilter Property
For a user-defined field called IsSupressed, and that users want to display only alarms where this field's value is different from zero, the expression to use is the following:
IsSupressed <> 0
To display only messages with "HIHI" or "LOLO" sub-conditions of alarm objects whose name starts with "Pressure", the expression to use is the following:
(SubConditionName = "HIHI" OR SubConditionName = "LOLO")
  AND (Mid(AlarmSourceName, 1, 8) = "Pressure")
