SetPoint |
This object works as an edit box in which contents are inserted to be attributed to associated Tags. To use this object, follow these procedures:
1.Select the SetPoint option on the toolbar of a Screen.
2.Click the Screen to create the object's origin vertex then drag the mouse diagonally to its final vertex.
3.Right-click the object to open its Properties Window. On the Item tab, select the Tag to link to the SetPoint's Value property.
