Interlocks |
Interlocks are intended to inform when there is a restriction to execute a Command. This restriction applies to all Commands on the same level and on lower levels. For example, an Interlock created on a Bay allows all Commands present on that Bay to be interlocked on devices. Likewise, an Interlock created on a Command Unit influences only that Unit.
Interlocks must be created on the Interlocks folder. To insert this folder, right-click the object and select the Add - Interlocks option.
To insert an Interlock, right-click the Interlocks folder and select the Insert - Interlock option.
Users can add several Interlocks in each folder, and only one of these Interlocks must be violated to trigger the Interlock.
For an Interlock to work properly, the ComparisonOperator, ComparisonValue, and Measurement properties must be configured.
Interlock properties can be checked on Elipse Power Reference and Scripts Manual.
