Counter Tag |
A Counter Tag is an object that counts time (in seconds) up to a pre-determined value, or even indefinitely. To use this resource, follow this procedure:
1.Right-click a Data Server and select the Insert - Panel - Counter Tag option.
Inserting a Counter Tag
2.The system opens up a window asking the number of Tags to create in the Server, as well as their names. This name is auto-incremented; if this option remains blank, Tags are created with a default name.
Adding Counter Tags
Some Counter Tag properties can be configured using the Properties List, without creating scripts for this. To configure any property, just locate it on the Properties List and perform the necessary adjustments.
