Creating an Application
To create a new application in Elipse Power, users must first create a Domain, which is responsible for gathering all application projects.
1.Execute Elipse Power Studio, select the Create a new Domain option, and then click OK. Application Wizard is then opened, and it helps users to create a new Domain.
Application Wizard
Application Wizard
2.Click Next. The following screen is then displayed.
Selecting an application type
3.Select the Standard application option. After indicating an application's name and a directory where this application must be saved (according to the previous figure), click Next. The following screen is then displayed.
Selecting a Domain
Selecting a Domain
4.Click Next again. The following screen is then displayed.
Selecting a Viewer resolution
5.Configure a screen resolution and click Next.
6.Answer No to question Do you want to install an I/O driver?. Click Next.
7.Answer Yes to question Do you want to store data in a database?. Keep the suggested file name, because this database is going to be changed to SQL Server later. Click Next.
8.Answer Yes to question Do you want an Alarm Server in your application? and select the Store alarm events in the database option. Click Next.
9.Finally, the following screen is then displayed.
Finishing Application Wizard
10.Click Finish. Elipse Power Studio is then opened.
Elipse Power Studio
Elipse Power Studio
11.With these procedures, this new Domain is ready to be configured.
