Preview a Report |
To preview a Report at run time, follow these procedures:
1.Insert a Command Button with the text "Report" at the bottom of Event_Screen.
2.On Click event, create a Print Report-type Pick.
3.In the Print Report field, select the AlarmReport item.
4.In the Output option, select the Screen item.
Print Report Pick
CHALLENGE XIV |
Create a button to export a report to an Excel file. |
TIP |
Use Report's Export method. |
