When to Create an ElipseX
There are some criteria that indicate the need to create objects in Elipse Power:
Usage repetition: If a device or process is used more than once on the same project
Procedures known by users: Usually, a process created by a certain company must be copy- or change-protected. This is common in case of service integrators or machinery manufacturers
Usage of controllers: A process controller, whose memory mapping is fixed, can be implemented with all available functionality. The available flexibility for creating and using Elipse Power objects allows users to use only variables needed, while ignoring the others
NOTE
Users cannot copy a library and use both files (original and copy) in the same Domain. For example, users cannot copy a .lib file and then split it into two new files.
