PowerCAD and Electrical Modeler
Fixed the undo operation when deleting collapsed elements using a Tie Node. This bug occurs since v5.1.84.
Fixed the color of a collapsed Node adjacent to a deleted element. This bug occurs since v5.1.84.
Fixed the display of a combo box after a collapse operation on Schematic Views. This bug occurs since v5.1.84.
Fixed a GPF when trying to locate a collapsed element using a Tie Node on a Schematic View. This bug occurs since v5.1.84.
Fixed an error where PowerCAD's Locate Elements window lost the typed text. This bug occurs since v4.7.119.
Fixed the redrawing of collapsed Connectors when moving their respective Tie Node. This bug occurs since v5.1.84.
Fixed the Or condition, which appeared as And on the Filter column on the Schematic Profiles window on the generation configurations of Schematic Views. This bug occurs since v4.8.151.
Fixed the connection point on Busbars of Schematic Views by script. This bug occurs since v5.0.122.
Fixed an incorrect return of the Count method of the Collection of Connections of Substations and Feeders. This bug occurs since v5.0.122.
