Elipse Power |
•Added support for Photovoltaic Power Plants in Elipse Power.
•Created the new objects Photovoltaic Power Plant, Photovoltaic Array, Photovoltaic Bay, Junction Box, Direct Current Branch, Photovoltaic String Group, Photovoltaic String, and Inverter, and created a default Analog Measurement *DcPower.
•Added the Screen objects Photovoltaic Array, Inverter, and Junction Box in the PowerControls library.
•The PowerControls library shows the full hierarchy in PowerExplorer when the type of an object is Photovoltaic Array.
•Implemented the reading and using the activation of licenses, at run time, of Photovoltaic Array and Inverter objects.
