Elipse Power Data Objects |
•Fixed a possible GPF when the active Measurement Source is changed in a reentrant way. This bug occurs since v3.5.81.
•Fixed a problem on the Discrete and Commands tabs of the Power Configuration object, which did not allow operating it via keyboard after removing an item. This bug occurs since v3.5.81.
•Fixed the behavior of properties that come from types, Caption and Unit, to remain empty if that type does not exist. This behavior occurred in Analog and Discrete Measurements and also in Commands. This bug occurs since v3.5.81.
•Fixed a problem in the Scripts Editor on the Commands tab of the Power Configuration, when an event was changed using the mouse wheel with the focus still in the Editor. This bug occurs since v3.5.81.
