PowerCAD and Electrical Modeler
Electrical Modeler's viewing area is not changed to the previous view when opening Elipse Power Studio's Customize window. This bug occurs since v3.5.81.
Electrical systems with only a large number of Substations do not consume 100% of CPU anymore. This bug occurs since v4.7.119.
Selecting a Container by clicking the viewing area does not clear the selection anymore when pressing mouse's left button. This bug occurs since v4.7.175.
Initializing, closing, and executing a Topological Processor are now faster in large networks. This bug occurs since v4.7.175.
Fixed a failure to regenerate CAD diagrams after zoom operations. This bug occurs since v4.7.129.
Internal hollow areas of Generator, Recloser, Breaker, Distribution Transformer, and Wind Turbine symbols can now be clicked. This bug occurs since v4.7.119.
Reduction of Feeders starts from the Substation configured in the Substation property. If a Feeder does not point to any Substation, the former rule is kept. This bug occurs since v4.7.215.
Improvements on the tool to locate elements in the Electrical Modeler to avoid slowness when finding many elements. This bug occurs since v4.7.119.
Elipse Power Studio does not hang anymore when minimized while the Power Configuration object is closed. This bug occurs since v4.8.16.
Fixed the position of a connection's target. This bug occurs since v4.8.207.
Shortcut key CTRL + Drag the mouse pointer repositions the selected Vertexes in any situation. This bug occurs since v4.7.216.
Closing the Electrical Modeler in some situations does not hang Elipse Power Studio anymore. This bug occurs since v4.8.16.
Added a verification to avoid a GPF when closing the Power Configuration object when the PowerCAD library is not registered. This bug occurs since v4.7.119.
Double-click a device in a Schematic View, leads to the physical device and also selects it. This bug occurs since v4.7.173.
Enabled a consecutive multiple selection by using the selection window with the SHIFT key. This bug occurs since v3.5.181.
Copying and pasting a Busbar Terminal with Terminals does not create disconnected Terminals anymore. This bug occurs since v3.5.181.
Copying and pasting isolated containers with isolated LinkNodes inside Bays does not create invalid containers anymore. Opening invalid containers already created does not cause a GPF in Elipse Power Studio anymore. This bug occurs since v4.8.158.
Fixed a preview visualization of CAD objects when switching a container. This bug occurs since v4.7.119.
Implemented shortcut keys on PowerCAD's toolbar also for electrical models in XPD format.
