Importing and Syncing Elipse Power Objects |
•The Elipse Power's Import Screen Objects tool now allows importing more than one object at a time, automatically creating the Screens, if needed.
•Created a tool for syncing data objects that exist on Elipse Power and still exist on the electrical model.
•Standardized the behavior of Elipse Power's Screen Importer, Data Object Syncing, and Existing Data Object Syncing tools for when there is an open Domain or not. Now users can only execute these tools if there is an open Domain in Elipse Power Studio.
•Created an option for users to inform if they want to resize a Screen, by keeping the size of objects defined in PowerControls library, instead of resizing objects to fit that Screen.
•The interface of Elipse Power's Import Screen Objects tool, which allows selecting a specific Screen, now allows renaming the folders created.
•The Elipse Power's Import Data Objects tool now uses projects already in the Domain, or allows overwriting projects closed outside the Domain.
•Implemented support for inverted axes on Elipse Power's Import Screen Objects tool.
•Implemented an option to allow selecting the background color for Screens created during Elipse Power's Screen objects import process.
•The Screen's Caption property where a Substation or Feeder is being imported, if still has its default value, receives the name of the Substation or Feeder imported.
•Changed the nomenclature of tools available on Power Configuration's Electrical Model menu.
•Implemented syncing of new data objects Recloser, Voltage Regulator, and Distribution Transformer.
•Implemented importing of Screen objects Recloser, Voltage Regulator, and Distribution Transformer.
•Implemented the import process of Schematic Views and included new configuration options on Advanced window.
