Elipse Power
Elipse Power
Fixed a problem on the list of classes to use when importing Elipse Power's Screen objects, which may be blank when clearing the selection, in an application generated in version 4.0 build 26 or earlier and then opened in version 4.5 build 159 or later. This bug occurs since v4.5.159.
Fixed the configuration of Command Template TapPosition in the demonstration application of Elipse Power. This bug occurs since v4.0.222.
Changed the formatting of Analog Measurements with type Date, Boolean, or Text. This bug occurs since v3.5.80.
Fixed the counting of Measurement objects in Elipse Power, which did not count Measurements inside Protections nor inside Load Shedding Scenarios. This bug occurs since v3.5.201.
Fixed the Power Flow algorithm, where quality of output measurements was not separated by electrical island. This bug occurs since v3.5.181.
Fixed a problem where Load Shedding Module's load was interrupted when there was one or more Three-Winding Transformers instantiated on an XPD file. This bug occurs since v3.5.226.
