Other Corrections |
•Corrected date, time, and time interval rounding when formatted with tenths or hundredths of seconds. This bug occurs since v4.0.133.
•Changed the way the number of threads was calculated in each Elipse Power process, used by ProcessInfo statistics, which used to nearly crash the system if there were a few hundred Drivers executing with enabled statistics. This bug occurs since v4.0.31.
•Changed REC channels sending and receiving logic to better tolerate slow networks situations. Also added Pending Packets column on E3 Admin Statistics window.
•Fixed the handling of paths where the dot was not required after a name between brackets. This bug occurs since v1.18.147.
