Remote Domains |
•Improved the performance of Elipse Power remote Links, by using a cache that keeps remote Links for at least 15 seconds, event when not used. This bug occurs since v3.2.108.
•Fixed a memory leak that could occur in an E3 Server when using Remote Domains with asynchronous Link creation. This bug occurs since v3.2.122.
•Fixed a memory leak that could occur in an E3 Server when a Remote Domain reconnected. This bug occurs since v3.0.201.
•Optimized removal of Remote Domain Links, now performed in blocks. This prevents client-side crashes when disconnecting from a server Remote Domain. This bug occurs since v3.0.201.
