Drivers and I/O Server |
•Corrected a memory leak in the file Et32b.dll. This leak may affect any Driver working with lists of values, but it was noticed first on DNP3 Driver with callbacks enabled.
•The configured dead band in Block Elements now works. This bug occurs since v1.18.147.
•Corrected a memory leak of a few KB which occurred in E3Run and Elipse Power Studio when a Driver was activated and deactivated. This bug occurs since v1.18.147.
