ElipseX Libraries |
•Corrected a problem with indirect links among ElipseX properties of type Object, which may not connect, depending on the order in which the properties were declared. This bug occurs since v1.20.282.
•Corrected the connection of links in ElipseX properties which referenced other properties of type Link of the same ElipseX. This bug occurs since v1.22.60.
