E3 Tweak |
•Included in E3 Tweak an option to control the module IOServer in the log section Track. This bug occurs since v3.1.32.
•Corrected the path of the registry key displayed in E3 Tweak interface on 64-bit operating systems. This bug occurs since v3.0.30.
•Now E3 Tweak considers the range of values of type DWord when editing items of numeric type. This bug occurs since v3.2.196.
•Corrected a problem when validating numeric values which occurred in cases where a value outside the default range was used to indicate that the item is disabled. This bug occurs since v3.2.196.
•Corrected problems on the registry key description and creation of the item Filter enabling, the COMFilter option, of E3 Tweak. This bug occurs since v3.1.30.
