Documentation |
•Corrected formatting and displaying problems with links in Elipse Power documentation in PDF documents included in the Downloads section of Elipse Software website. This bug occurs since v3.2.242.
•Added a chapter in all Elipse Power manuals with search tips for CHM documents. This bug occurs since v3.2.115.
•Corrected the default value of the EnableReadGrouping property of the I/O Driver object in the item Drivers - I/O Driver - Methods on Elipse Power Reference and Scripts Manual. The correct default value of this property is True. This bug occurs since v2.0.135.
•Corrected the examples of use of the LoadFormulaValuesQuiet method of Formula and Viewer objects on Elipse Power Reference and Scripts Manual. This bug occurs since v1.22.30.
•Added descriptions to the RenameValue, SaveFormulaValues, SetUnitData, and SetValueData methods of the Formula object on Elipse Power Reference and Scripts Manual. This bug occurs since v3.2.140.
•Corrected the description of the Query method of the Report object, to exclude the reference to the SourceQuery property, which is a private property of the Report. This bug occurs since v1.20.418.
•Corrected the description of the AllowAckSelected property of the E3Alarm object and the name of the chapter about User Libraries on Elipse Power Reference and Scripts Manual, to match Elipse Power User's Guide. This bug occurs since v1.21.150.
•Corrected example scripts of the AddObject method and the Application and Links properties, all from the chapter Programming in Elipse Power, on Elipse Power Reference and Scripts Manual. This bug occurs since v3.2.151.
•The FillStyle property now is described only in the properties of the Screen object, containing all values and restrictions for all Screen objects. This bug occurs since v1.22.37.
•Added descriptions for the CommErrorBkColor, CommErrorText, CommErrorTextColor, and EnableCommError properties of the Viewer object on Elipse Power Reference and Scripts Manual. This bug occurs since v1.21.144.
•Added to Elipse Power Reference and Scripts Manual the description of the nRetries property of the Database object. This bug occurs since v3.0.218.
•Added the description of the AboutBox method of the E3Alarm object on Elipse Power Reference and Scripts Manual. This bug occurs since v1.21.109.
•Added the description of the AboutBox method of the E3Browser object on Elipse Power Reference and Scripts Manual. This bug occurs since v1.21.109.
•Added the description of the Retentive property of the Property object of an XObject on Elipse Power Reference and Scripts Manual. This bug occurs since v3.2.151.
•Added descriptions for several properties of the IOFolder, OPCGroup, DrawGroup, DynamicRotate, and XMethod objects, and also properties common to Screen objects. This bug occurs since v3.2.140.
•Added the value corresponding to the option of centering the window (2048) in the description of the Flags parameter of the SetFrameOptions method of the FrameSet object, on Elipse Power Reference and Scripts Manual. This bug occurs since v1.21.123.
•Added a Locate button on the toolbar of CHM files, which allows locating the selected topic in the Search tab during a search. This bug occurs since v3.2.131.
•Replaced the figure displaying a Multiple Connection in the chapter Links of Elipse Power User's Guide, to a more representative figure of this type of connection. This bug occurs since v3.2.136.
•Corrected the description of the functionality of the field Ping Addresses to check network integrity, which is not quit immediately when detecting network interface problems, but enter the Standby mode. This bug occurs since v1.20.364.
•Corrected the description of the animation options of menus in Elipse Power Studio on Elipse Power User's Guide to include the Default item, default for Windows, to differentiate from the None option, default for Elipse Power. This bug occurs since v2.0.124.
•Added direct links to events, methods, and properties on Elipse Power Reference and Scripts Manual which are referenced on Elipse Power User's Guide. This bug occurs since v3.2.131.
•Added information on Elipse Power User's Guide about the need of a specific protection device license to use Elipse Power as an OPC server. This bug occurs since v3.0.233.
•Added a description of the procedures to enable ports on Windows XP, Windows Vista, and Windows 7 Firewall on Elipse Power User's Guide. This bug occurs since v2.5.28.
•Corrected the description of the item Query Object in the chapter Reports of Elipse Power User's Guide. This bug occurs since v1.20.418.
•Corrected texts in several chapters of Elipse Power User's Guide. This bug occurs since v3.2.131.
•Corrected the description of the measurement unit of the MaxRecTime column, in the chapter about Storage Configuration on Elipse Power User's Guide. This bug occurs since v1.21.135.
