ActiveX
ActiveX
Corrected a problem with a class registered by the user not showing on the list to be inserted in Elipse Power, nor showing any registry error message. For this, the window Add ActiveX was redesigned, aiming to make it easy to register new controls, as well as viewing the ones already loaded in Elipse Power. This window was renamed to ActiveX Control Configuration. This bug occurs since v1.18.147.
ActiveX Control Configuration window
