Methods
Methods
This section contains information about the common methods of Elipse Power objects. Each topic displays the name of a method with its respective parameters, in its correct syntax, and also a usage example. The available methods on this section are the following:
Activate
AddObject
Context
Deactivate
DeleteObject
GetChildObject
GetObject
Item
Save
