Trace
Trace
Trace(MessageText, [LogTimeStamp], [BreakLine])
This method allows registering messages in Elipse Power's log. This method can be used, for example, to register debugging messages for scripts executed in Elipse Power Viewer.
Parameters of the Trace method
Parameter
Description
MessageText
A user-defined message
LogTimeStamp
A Boolean indicating whether each record must contain a timestamp. This parameter is optional and ignored in Elipse Power Viewer
BreakLine
A Boolean indicating whether a line break must exist at the end of each message. This parameter is optional and ignored in Elipse Power Viewer
