AdviseType |
Controls the Advise mode. The available options are described on the next table.
Available options for the AdviseType property
Option |
Description |
0 - AlwaysInAdvise |
OPC UA Tag is kept updated if the AllowRead property is set to True and the OPC UA Subscription's Enable property is also set to True |
1 - AdviseWhenLinked |
OPC UA Tag is only updated if the OPC UA Subscription's AllowRead and Enable properties are set to True and this Tag is linked to any active object, such as a Display on an open Screen or an enabled Alarm, among others. This Tag's link for this purpose can be performed on the following properties: Value, RawValue, TimeStamp, Quality, and Bit00 to Bit31 of OPC UA Tags (default) |
