ScreenAlignment |
Controls the alignment of a Screen relative to the visible area. Possible values for this property are the following:
•0 - paDefault: Adjusts the Screen to follow the value configured in Viewer's ScreenAlignment property. It corresponds to the Use Default option of a Screen's Alignment (This Screen) contextual menu, at run time
The next figure shows the contextual menu of a Screen at run time, with the respective configuration options of this property.
Options for a Screen's ScreenAlignment property at run time
