CommandType |
Defines the Command type, using the name configured on the Command tab of the Power Configuration object. This property's value can be configured in the Property List, as well as in the Type column of the Design tab of Feeder, Photovoltaic Power Plant, Substation, Transmission Line, and Wind Power Plant objects. This property cannot be changed while this object is active and cannot be an empty String.
