TabsEnabled |
Allows configuring which tabs are visible on PowerExplorer's window. If this window is already open, these tabs are immediately updated. This property accepts a combination of the following values:
•1: Displays only the Analog tab
•2: Displays only the Discrete tab
•4: Displays only the Command tab
•8: Displays only the Protection tab
For example, the value 3 displays Analog and Discrete tabs and hides Command and Protection tabs. The value 12 displays Command and Protection tabs and hides Analog and Discrete tabs. The special value -1 always displays all tabs (default value). The value 0 (zero) is not accepted, that is, users cannot hide all tabs (this attempt generates a script error).
