ActiveTab
ActiveTab
Text Returns or selects the active tab on PowerExplorer's window. If the name configured in this property is invalid (an empty String or a non-existent tab name), a script error is then generated. This property is updated whenever a new tab is selected on PowerExplorer's window. Likewise, if the active tab is removed, by using the RemoveScreenTab method, this property is also updated to reflect the new active tab.
