Semantics |
This property returns an object that allows configuring Semantics for a Discrete Measurement Type by script. Semantics of Discrete Measurement Types are available on the Discrete tab of the Power Configuration object. To use the object returned by this property at run time, users must deactivate the Power Configuration object before changing its properties.
NOTE |
Please check topic Semantics for more information about the properties of the object returned by this property. |
