ModelFile |
Path of the electrical model file (in XPD or EDB format). This path, if relative, considers the project's path that contains the Power Configuration object. This property cannot be changed while this object is active.
NOTE |
For applications earlier than version 4.7, the default electrical model file is XPD. Starting with version 4.7, the default format is EDB. |
